rear windscreen wiper
hi all im a new guy , with a problem , i have a f2 coupe,live in uk , my problem is this , my rear windscreen wiper has recently packed up , im hoping it is the fuse , but where the hell is it , its not marked on the fuse box, faling that anybody got any other ideas???
i know it could be the switch or i may have to trace it back but was hoping to start with fuse, ive checked all the blade fuses they are fine.... HELP!!!
RE: rear windscreen wiper
Double check all the fuses, in the car, and under the hood (bonnett?)
It should be fairly easy to get to the rear wiper motor. Disconnect it, and with a test light or voltmeter check the plug for power, while the rear wiper switch is turned on.
If there is power, than you have a faulty motor. If there is not any power, then there is another electrical problem, which could really be anywhere.
Not sure about the F2, but on my Elantra there is a bin next to the steering wheel that opens and closes. If you pull the whole bin out, the passenger compartment fuse block is behind that. There should be a fuse map on the back of the bin.
ok just been out and checked guess what? there is a seperate fuse box in the driver side footwell checked the fuses and hey presto a working rear windscreen wiper thanks to everyone who helped me out here and i hope i can do the same for you sometime , im off to go bury my head in a bucket of sand in shame , thanks agian
danieleonharper
01-09-2009 08:20 PM
