windows problem Accent 2001
Hi guys. I want to ask a question. I wanted to see why the button for the passengers side isn't opening the window, but just closing, and suddenly both of the windows that were open, just closed, and now i can't open them. It is hatchback, so only 2 widows can open, and I touched the buttons on the left door, drivers side. Thanks
From the description, it is a right hand drive vehicle and only has two doors and a hatch.
The two windows that were open suddenly just closed
That sounds like a switch or wiring issue.
Troubleshooting would require investigating the window motors and window regulators
If you have no experience in this then best to seek a professional
If you do then you should be able to determine where the issue is and replace the defective part
Good luck
Good luck
