03 accent clutch, slave, booster?
Old Feb 25, 2008 | 05:04 PM
Ukonjack's Avatar
Default 03 accent clutch, slave, booster?
Have a 2003 Accent 1.5L, 5spd, dealer says the clutch is on the way out. $900 to replace the clutch, pressure plate, bearing and have the flywheel machined, ouch. 87,000km
Its a bit difficult to get into any gear, double clutching and I can shift into gears easy.
Last year the dealer said the clutch needed adjustment during a routine service. Now they say that there is no adjustment left, I don't see any place to make an adjustment. Is there an adjustment or not? hmmmm
I cannot find an aftermarket clutch kit for this year and engine combo, they all show the engineas a 1.6L for a 2003. Couldthis bean early 2003 model or something ?, do I order a clutch kitfor 1.5L,2002?
Hydraulic fluid is full, but could this be a master or slave issue??
Can the clutch be replaced without dropping the motor/trans out the bottom, or is there enough room to separate them in the engine bay?
Any ideas????
Thanks.
Old Mar 9, 2008 | 07:25 PM
bsw357's Avatar
Default RE: 03 accent clutch, slave, booster?
Check on the Slave cylinder by removing the boot, Replace the Slave cylinder if it's wet inside the boot.
wetsail
Nov 13, 2011 09:24 PM
jack
Dec 12, 2009 11:55 AM
BaVinic
Dec 7, 2009 12:28 PM
speeder
Mar 9, 2008 07:05 PM
dde
Aug 17, 2005 11:09 AM
