2001 hyundai accent GS Hatchback- slow acceleration
Old Jun 29, 2010 | 01:34 PM
sufsuf92's Avatar
Default 2001 hyundai accent GS Hatchback- slow acceleration
Hello,
I just bought a 2001 Hyundai Accent and i love the car and all but it has really slow acceleration. When you first start moving with the car it's extremely slow but once you get 35+mph than it starts behaving better. I was just wondering if this is normal in the other hyundai's or if it is a problem. If it is a problem than what could it be?
Please ANY help is appreciated.
Thank you.
Old Jun 29, 2010 | 02:12 PM
105 horsepower and 106 ft-lbs torque don't make for brisk acceleration even when new (I believe it was about 11 seconds 0-60). Now that it's 9 years old, I'd expect even less.
Old Jun 29, 2010 | 02:21 PM
sufsuf92's Avatar
Ok just making sure, thank your very much though!!
Old Jun 29, 2010 | 02:24 PM
Is it an automatic or manual? How many miles? A tune-up couldn't hurt but don't expect acceleration that might cause neck injuries.
Old Jun 30, 2010 | 10:19 AM
zero_gravity's Avatar
Banned
if its an auto they're agnozingly slow even when they're new...i won't drive the auto myself.
a general tuneup is always a good idea when maintenance history is unknown. here's where i'd start:
-engine coolant
-spark plugs (i recommend 0.035" for the 1.6L instead of the specified 0.045" for misfire issues)
-air filter. a clogged one won't hurt fuel economy, but it sure will slow you down!
-auto trans: fluid flush. be sure the right fluid is being used.
-manual trans: change the gear oil, hyundai spec is 75W-80 API GL-4 i believe. double check your owners manual. also note that no matter what you're told GL-5 is NOT compatible with GL-4! GL-5 can damage the transmission. also i recommend full synthetic for a tad more power
-always a good idea to inspect brakes as well.
this is not a list to 'get done for sure' but a list of things to inspect. if you're unsure how, post here or PM me and i'd be happy to help. if you're doing your own work here's a few other things worth doing, but not really worth paying someone for:
-PCV valve: check if its functional/clean
-Throttle body cleaning
-fuel filter
-injector cleaning - take them out and clean them properly.
-plug wires
-brake fluid and clutch fluid (if you have a manual, clutch also uses brake fluid)
johnseg11
Oct 28, 2014 01:51 AM
Weaponhead
Jul 25, 2012 07:27 PM
MN220_3
Nov 2, 2008 05:18 PM
Elantra
May 5, 2007 08:41 PM
stankydanky78
Oct 29, 2006 03:08 PM
