2004 Hyundai Accent P0501
182,000 miles, hatchback, GL, Auto trans
Speedometer and Odometer inop. tranny shifts great after fixing P0734 by replacing a destroyed overdrive bearing. Replaced Vehicle Speed Sensor and still no change. Check voltage at VSS input plug, ground is good, battery wire showing around 11V and pulse wire around 7V. Verified that there are no speed sensors on both front wheels. Ordered and waiting on a VSS gear which looks good to me but there's a few chips of the gear teeth missing. Checked all the fuses in the engine bay and driver's kick panel, no blown fuses. Didn't check the instrument cluster yet but will do so if the new gear doesn't fix the problem. Appreciate any help, thanks!!
Sorry, I forgot to mention that I have a non ABS model. There are only the regular brake lines going to the wheel area.
In doing some checking, ABS was not required until around 2007-8.
The speed sensor signal from the sensor you installed should go up to the inst cluster. You might need a diagram or the use of a scan tool to verify if the cluster is getting the signal or do it the hard way and physically trace the wire and check if it is getting up there, which if it is, the cluster could have a problem.
I used my BlueDriver scan tool and was unable to get any MPH reading off the Live Data. Also my left turn signal bulb indicator in the dash intermittently works so maybe I just need to spray some electrical cleaner in the dash wiring.
Not sure if there is a printed circuit board used in the inst cluster. Quite a few times all it required was to unplug and reinstall the plug to correct a possible poor connection.
The quick check before reassembling everything might be to see what that left turn indicator does.
I actually had the instrument cluster out a few times to replace the stock lights with LED's. The connections look good back there but I'll take a better look this time around. I should be getting the VSS gear today so fingers crossed.
Yeah the new gear didn't work. Odometer and speedo still inop. I even took out the instrument cluster and sprayed electronic cleaner in the harness also. I have a suspicion that the 7 volt reference might have something to do with it. I still have to check the wiring from the VSS to wherever it goes.
