2013 Accent P0016, P0017, P0326, P0366
Old Jun 17, 2021 | 01:31 PM
garrwoof's Avatar
Angry 2013 Accent P0016, P0017, P0326, P0366
Accent throws up above errors. Also battery light comes on while driving if radio, fan on high.
So far on advice from local mechanic replaced:
timing chain
Cam phazors
Crank sensor
cam sensors
oil control valve
ECM/ECU
He has checked all the wiring, verified alt is charging and has no open or short to ecm. (also verified timing is correct).
His last advice was ECM but after replacement I have the exact same problems! Any and all help is greatly appreciated!
Old Jun 18, 2021 | 07:30 AM
From the info provided , it appears the person doing the repairs is looking only at the mechanical aspects of the problem and not the electrical parts.
There is something all the codes seem to have in common and that is the electrical part.
It would be wise to verify correct power and grounds to the systems and sensors involved. Replacing good parts can get pretty expensive and disappointing.
If the person doing the repairs doesn't have the info or background to follow through with this problem, you might consider having more experienced shop check the vehicle out...
garrwoof
Jun 17, 2021 01:30 PM
Goos
Oct 3, 2020 03:07 PM
ampmadscientist
Aug 30, 2018 06:07 PM
Jsb
Jan 24, 2018 12:32 PM
pizzaman
Feb 8, 2013 10:05 AM
