Key fob quit working
Old May 13, 2021 | 09:03 PM
Bugly's Avatar
Default Key fob quit working
Hello all,
First post here but am a member of several similar forums. 2006 Accent 96000 miles automatic. I did a search but could not find an answer. Before I purchase a new key fob I have a question. The fob worked when we got the car but then stopped working. Figuring the battery was dead on the fob so I bought and installed a new one. Still did not work. When you push the lock / unlock buttons the red light on the fob flashes. Then I remembered that the car battery ran dead the other day so I googled instructions on how to reset the fob. Key on ACC and held the unlock button on. Still no work. I then tried this procedure with the lock button. Still no work. Does anyone have a solution, or is there another reset procedure I can try. Just want to be sure before I buy another fob. Lastly, will a new fob require programming at a dealer or locksmith?
Thanks for any suggestions,
Kevin
Old May 14, 2021 | 06:36 AM
There are times when we need to verify what we do.
Are we sure the battery that was installed in the FOB was good?
Someone should check that and make sure that is not overlooked.
Old May 15, 2021 | 12:15 AM
Bugly's Avatar
Brand new battery installed exactly like the old one came out. I checked the new battery and it tested good. Pretty straightforward
Old Jun 18, 2021 | 10:54 AM
RandySamuel's Avatar
I asked locksmith fort worth to change the battery and after replacement of battery it works fine.
Old Jun 18, 2021 | 11:07 AM
Thanks for the update.
lilyd123
Jul 17, 2020 02:25 PM
Beth Allison Thompson
Aug 19, 2019 12:17 PM
neilage
Nov 11, 2015 08:23 AM
jvaldes
Oct 5, 2015 02:30 PM
coupeladlee
Nov 4, 2010 04:55 PM
