97 Accent 120k, It will not go above about 2300 rpms
Old Mar 15, 2006 | 12:20 PM
fred_b's Avatar
Default 97 Accent 120k, It will not go above about 2300 rpms
97 Accent Automatic, 120K 12 valve. The engine will not go above 2300 rpm, having no power. I change the wires. plugs and coil pack with no luck. Could somebody help.
Thanks in advance.
Fred
I hope this is the right forum, as I'm not sure which forum to use.
Old Mar 16, 2006 | 02:25 AM
poacher's Avatar
Default RE: 97 Accent 120k, It will not go above about 2300 rpms
This is the right forum! As for your problem, it could be a ton of little things and I don't know where to begin.
Old Jul 13, 2007 | 01:14 PM
cliffjumper's Avatar
i just got a 2000 accent with 154000mi and the poor thing couldn't get over 2000rpms. The check engine was on all the time, and if i had enoght room to get it to 35-40, the light would flash and i'd loose all power completly. Well, long story short it turned out to be a Mass Air Flow sensor. $100 5 min. job. Runs like a champ.
Old Jul 13, 2007 | 01:17 PM
that or the little hamster inside the engine is just too tired. try giving it a fresh carrot.javascript:void(AddText(''))
iyanachk
Apr 20, 2014 07:55 PM
ElantraDan330
Aug 19, 2010 08:27 PM
SupraG35
Mar 1, 2008 10:34 PM
outtowinpahc
Feb 9, 2008 11:06 AM
fred_b
Apr 17, 2006 01:33 PM
