'99 Brake Lights
Old May 24, 2009 | 02:55 PM
Ricklee64's Avatar
Default '99 Brake Lights
My left & right brake lights are not working. The bulbs are good, and the CENTER light works fine. I've checked the fusebox, but can't figure out which fuse is for brakes. The fuse for Backup/Turn signal lights is good. However, if the center light works, is it not on the same circuit as the L&R? Any idea why they aren't working?
Old May 24, 2009 | 02:59 PM
Ricklee64's Avatar
Forgot to mention that it is the base model Accent.
Old May 24, 2009 | 07:44 PM
jsinton's Avatar
Banned
Couldn't find a diagram of the fuse box, maybe someone else can do that.
Sounds like a fuse, but could be a broken wire. Just take out all the 10 amp fuses and look at them.
Old May 25, 2009 | 12:25 PM
ken99's Avatar
There can only be one of two possibilities. 1) a common lead feeding voltage from the brake light switch to the corner lamps is broken or disconnected (see below) or 2) a common ground wire to the corner lights is corroded or broken. All three brake lights are fed by fuse #4 in the dash fuse box. Since the center light is working, the fuse isn't involved. Unplug the sockets and remove the bulbs to the corner units. Use a multimeter to check for voltage to the sockets while someone presses on the brake pedal. Switch the meter to measure ohms and then check the ground side of the socket for continuity. I am curious if you have checked the tail lights lately.
STOP LAMPS SCHEMATIC
Also, check connector MR05 near the left rear unit. Voltage for both corner rear stop lights passes through this connector.
Old May 25, 2009 | 02:23 PM
Ricklee64's Avatar
Wow. Thanks for all the info. Unfortunately I didn't check this until I had to go to work (on a holiday). I did try to get to the center brake light, but couldn't figure it out. I got the housing off, but couldn't get it unplugged to remove it all the way. After re-assembling it, the light no longer works. I couldn't get to the wiring harness behind the panel in the back. Maybe it's loose. I guess I'll have to take it to the dealer. Thank you for the great information.
Old May 29, 2009 | 09:18 AM
Ricklee64's Avatar
UPDATE. I took the car to the Hyundai shop. The mechanic checked the electical system and it took him 2 hours to find out that both bulbs were bad. Remember that the bulbs looked good with intact filaments. Very strange.
Old Jun 8, 2009 | 05:29 PM
samabhi124's Avatar
I think you should check the wiring completely.
tocrazie
Oct 16, 2014 01:49 PM
mtbrain3343
May 21, 2012 02:30 PM
Log2
Mar 1, 2012 09:52 PM
Rhanck
Sep 3, 2011 07:41 PM
DOH
Jan 20, 2009 07:47 PM
