Clutch do not shift when hot
Old May 27, 2011 | 11:14 AM
Ranga's Avatar
Thumbs up Clutch do not shift when hot
I have Hyundai Accent 2004 Manual.
When it is cold at the startup and up to 10-20 miles I can change gears smoothly. But after that it starts getting hard and very difficult to change. If I pump clutch pedal 2-3 times i can change gears. When it in top gear 5 and on highway I drove 300 miles no problem
When I checked Clutch oil it was very very dirty. I am replacing / replenishment it from top, by emptying small container and putting new but no improvement.
Any Idea what is the problem.
Old May 27, 2011 | 11:24 AM
You need to replace all the fluid, not just what is in the slave cylinder. And bleed the system. You probably have water and/or air in the lines.
Old May 27, 2011 | 11:27 AM
Ranga's Avatar
Default thanks
I am not very tech how to replace or bleed oil
Thanks a lot
Old May 27, 2011 | 12:36 PM
Then take it to a mechanic.
Old May 28, 2011 | 08:54 AM
Ranga's Avatar
Default I replaced oil and did bleed
how many gallons it give but unfortunately problem stays
uemaco
Sep 21, 2013 10:29 AM
Trev75
Feb 9, 2012 05:37 PM
andrewf
Mar 8, 2011 04:47 AM
ElantraOwners
Jan 24, 2011 08:07 PM
hidef56
Jul 16, 2009 09:52 PM
