Engine problem effecting transmission
Old Mar 19, 2010 | 09:40 AM
Almyghty1's Avatar
Default Engine problem effecting transmission
I have a 2004 Accent. The check engine light is on, saying misfire in cylinder 4. I have changed the plugs, wires, and coil. My next guess is an exhaust valve. The light has been on for a while now.
The car rides a little rough, and sometimes the transmission hesitates. I had the tranny checked, and he said it's fine, and the problem is in the engine skip.
The problem was worse in the fall, but the car started running better in the cold weather, so I let it go. Now that it's getting warmer, the problem is coming back. Yesterday, the engine was whistling while idling. As I stepped on the gas, it went away. When I let off the gas, the whistle came back. When I got home I was going to check it out, but it was gone.
Any thoughts?
Old Mar 19, 2010 | 11:31 AM
Yep, look for cracked intake manifold gasket at #4... a spritz of carb spray should do the trick..
Gasket is something like $6, add labor... not too hard to do, had 1 a couple week ago.
Old Mar 23, 2010 | 06:28 PM
Almyghty1's Avatar
Smile
Thanks for the reply, and good call, you hit the problem head on. Getting it fixed now
dwalker50
Apr 29, 2014 05:38 PM
dwalker50
Jan 16, 2011 05:09 PM
seane77
Oct 23, 2006 03:50 PM
malanam
Jun 16, 2005 04:11 AM
HyundaiortheHighway
May 6, 2005 12:10 AM
