fuel filter
Old Mar 16, 2007 | 12:09 AM
fiya_burn's Avatar
Default fuel filter
it really kills me that people say that the fuel filter is under the seat cushion and some people tell me to remove the gas tank.... can someone give me an actual fuel filter location and how to get to it please!?
Old Mar 16, 2007 | 12:40 AM
Doohickie's Avatar
Default RE: fuel filter
Both are correct. It is in the fuel tank, which is accessed by removing the rear seat, then removing a panel to reveal the top of the fuel tank. You need to remove the fuel pump from the tank to get to the filter, which is integral to the pump. I am not familiar with the Accent as much as the Elantra.... email me through my profile if you want a link to directions for the Elantra (I bet Accent is very similar).
Old Mar 16, 2007 | 03:14 AM
seiken's Avatar
Service and Repair
Notes
FUEL FILTER REPLACEMENT[*]Reduce the internal pressure of the fuel lines and hoses by completing the following operations.
[ol][/ol]
[ul][*]After removing the rear seat cushion, disconnect the fuel pump harness.[*]Start the engine. Allow it to stop by itself, then turn the ignition switch OFF .[*]Disconnect the battery negative (-) terminal.[*]Connect the fuel pump harness connector.[/ul]
[ul][/ul][*]Remove the eye bolts while holding the fuel filter nuts securely.
[ol][/ol]
CAUTION:[/b] Cover the fuel filter with a shop towel to avoid residual gasoline from splashing.[*]Remove the fuel filter mounting bolts, then remove the fuel filter from the fuel filter clamp.
[ol][/ol][*]After replacing the fuel filter, check for fuel leaks.
[ol][/ol]
this is for a 2000, im just guessing its the same car from the last post
Edit*
odd, there were pictures a minute ago
Old Mar 16, 2007 | 06:59 PM
fiya_burn's Avatar
ahhh i see so they both were right but they gave half-a..... butt info.... thanks
Paulus
Mar 11, 2013 10:29 AM
Aggie_1990
Jan 17, 2012 12:28 PM
2001accent
Sep 13, 2011 08:54 PM
bglick12
Jul 16, 2010 06:19 AM
derek slang
May 18, 2007 06:59 PM
