Fuel smell !!!
Old Dec 27, 2006 | 10:58 PM
jamie lewis's Avatar
Default Fuel smell !!!
Hi there,I am new to this forum and was wondering if anybody could help me with a problem I have with my 2000 model GLS.When I am driving it,every now and again there is a very strong fuel smell inside the car,it lasts maybe anything upto a minute and then disappears.Has anybody come across this problem before,your help would be most welcome,regards,Jamie
Old Jan 1, 2007 | 12:27 PM
Chris B Williams's Avatar
Default RE: Fuel smell !!!
Your'e not overfilling your tank are you?
Old Jan 2, 2007 | 11:01 PM
Thanks for the reply,
I am not overfilling the tank,the smell is coming from the engine bay into the cab via the vents,I recently gapped the plugs and this has helped a bit but the smell is still there.It appears to be worse after a short burst of reasonably hard acceleration,any ideas anyone??
Old Jan 8, 2007 | 12:46 AM
dodgethis2000's Avatar
I'd check the fuel pressure. If you've noticed a decrease in mileage, check out your O2 sensor. If it's starting to fail, or has failed, the PCM (computer) will give the engine more fuel to compensate.
Old Nov 2, 2007 | 05:57 PM
Mountain's Avatar
Hi Jamie,
I have noticed exactly the same thing on my 2000 Accent.
Dodge, any more info on cost/changing the O2 sensor? I'm still stuck in the days of distributers and this newfangled ECU stuff is beyond me
Cheers
Martin
Old Dec 5, 2007 | 11:59 AM
naemadi's Avatar
I have a 2002 XG350 with a similar problem. Over the past two years I have taken it to the dealer twice. The problem happens when it is cold outside or it is rainy. I have paid over $350 to have a fuel pressure regulator changed and a leaking fuel line replaced per the dealer's diagnostics but the problem did not go away. I've probably taken it back to the dealer 6 times and they can not seem to get to the bottom of this. Any thoughts?
Old Jun 8, 2011 | 03:46 PM
boosted's Avatar
I have this problem in my 2011 Sonota as well. Fuel smell coming through the vents when I am stopped. It literally stinks that they have this problem on so many different models and years. You would think they could have figured this out by now.
target
Oct 10, 2012 06:38 AM
steverinaz
Nov 2, 2011 09:12 PM
Sunseeker
Feb 11, 2011 08:15 PM
synapz
Sep 10, 2007 01:34 AM
hyundaioryota
Mar 18, 2006 05:18 AM
