little problem
Old Sep 1, 2006 | 03:12 PM
sameoldd5's Avatar
Default little problem
ok i have a 4 door accent....and the driver side rear window wont go up. i'm not sure if its the motor or what, but it has alot of play. like i can pull it up and push it down easily. i know its still on track...so any ideas on how i can fix this thing?
Thanks,
Dave
Old Jan 12, 2007 | 05:11 PM
Casper84's Avatar
Default RE: little problem
Its most likly your window motor burnt out.
Just take door panel off and push window up to a certain highth to get to motor sometime it can be a pain to get to and you will have to take it in.
Hope this helps
Old Jan 14, 2007 | 02:17 PM
Chris B Williams's Avatar
Whe you operate the window switch can you hear the motor run?
If the motor had burnt out I wouldn't have thought you could move the window by hand because of the gearing, it sounds to me as though there is no mechanical connection between the motor and window mechanism.
Best of luck,
Chris.
Old Jan 17, 2007 | 02:30 PM
sameoldd5's Avatar
ok i took the door panel off...i can hear the motor run, it sounds like its grinding some, almost like there's sand in it, but it still moves. the little wire cords that it pulls on moves too, i cant figure out where the problem is though...i know it has to be mechanical, but i cant get a working view at to what is going on
Old Jan 29, 2007 | 07:30 PM
flave1's Avatar
another common fault on these is the door regulator collapsing .sounds like yours needs replacing.
Timotheus08
Jun 12, 2009 06:59 AM
Derk479
Sep 19, 2008 11:19 PM
Derk479
Sep 19, 2008 02:04 AM
squamous
Apr 22, 2005 07:44 PM
