OEM radio/XM/CD unit in 2008 Accent quit working - troubleshooting advice?
Old Oct 22, 2021 | 10:23 AM
slmjim's Avatar
Default OEM radio/XM/CD unit in 2008 Accent quit working - troubleshooting advice?
It's the version that has CD player and XM Radio built in. No power, no LCD display. Just dead.
PN# 96110-1E085CA
Model A-200 MC A3A
Barcode # BKU8301102
Fuses are good.
We bought the car new. Unless a forum member has some troubleshooting advice, I'd like to replace it with a good used one of the same model.
I'll be posting in the 'Wanted' forum soon as I pull the unit & confirm the precise part #. I'd rather buy from a trusted forum member than from fleaBay.
slmjim
EDIT to add:
12V present on R (+).
Switched 12V is present on G when ign. sw. is on ACC and IGN.
Old Oct 22, 2021 | 02:23 PM
A little side note,
Any electrical device in a vehicle needs to have , Power and Ground to operate.
Checking the fuse is only part of the job. We need to check at the radio itself to confirm power is available there and a good ground connection too..
If you cannot manage to do this , consider having a radio shop or someone with a little electrical background check this. You may not need another radio unit.
Old Oct 23, 2021 | 02:44 PM
slmjim's Avatar
Originally Posted by hanky
... We need to check at the radio itself to confirm power is available there and a good ground connection too.
In hindsight I left that part out.
OP has been edited accordingly.
slmjim
Old Oct 24, 2021 | 12:58 PM
How did you verify a good ground is available?
Old Oct 26, 2021 | 09:55 AM
slmjim's Avatar
Continuity from black GND pin to vehicle chassis ground.
slmjim
Old Nov 10, 2021 | 07:47 AM
slmjim's Avatar
It was the radio. A good used unit of the same model from fleaBay for $80.00 USD was a simple P&P.. We have tunes again.
Thanks to all who replied.
slmjim
Natsem
Aug 10, 2010 03:35 PM
nevis111
May 18, 2010 04:25 PM
SHOZ
Sep 29, 2008 11:45 AM
alevine
Sep 26, 2008 02:36 AM
cstephen
Oct 29, 2007 06:27 PM
