Oil Drain PLug Location. What?!?!
Old Oct 6, 2020 | 01:52 PM
RHamilton1's Avatar
Default Oil Drain PLug Location. What?!?!
I've done a lot of work on my '13 Accent but I've never changed my own oil. I figured it's time. But the drain plug location faces forward, so when I put my Accent on ramps I can't drain much oil. What's the secret?
Obviously, as low as this car sits to the ground I've got get under to access the plug and filter. Or what? I guess I could roll the car back off the ramps, allow it to drain, replace the drain plug and go back on the ramps to remove/replace filter?
How are you guys doing it?
Old Oct 6, 2020 | 03:36 PM
Sometimes you need to jack up the rear so the pan drains, then let it down and complete the oil and filter change.
Old Oct 17, 2020 | 06:53 PM
RHamilton1's Avatar
That's what I ended up doing. It was the only thing that made sense.
Thanks!
SkipII
Mar 7, 2016 07:14 AM
ritchep
Jul 2, 2012 01:36 PM
riebe
Dec 26, 2011 08:22 PM
Login
Oct 22, 2010 09:22 AM
Jagson75
Jul 29, 2009 09:15 PM
