Pulls to side when accellerating
Old Oct 31, 2010 | 02:39 PM
rcacs's Avatar
Default Pulls to side when accellerating
2001 Accent GSI with manual trans. When accelerating, especially right after a shift, the car noticably pulls to the side.
Anyone else had this problem and found the cure?
I checked the engine mounts and all is well there.
Cheers
Old Oct 31, 2010 | 05:46 PM
There occurrance is known as "Torque Steer"... comes from application of power (torque) and the un-equal length drive shafts.. left side is short, right side is 2x longer from drive unit to wheel bearing..
Now you can brag to the unsuspecting riding with you that your car has so much power that it takes the steering away from you..
Old Oct 31, 2010 | 07:01 PM
rcacs's Avatar
Actually, it never used to do this, and it surely hasnt gained any great amount of power recently.
This is much more than what you are describing.
cheers
Old Nov 3, 2010 | 09:11 AM
wolfman's Avatar
You should check to make sure that you do not have a brake dragging. An obstruction in one of the lines can cause the brake caliper to release slowly.
Old Nov 9, 2010 | 07:19 PM
nichaaron's Avatar
my '03 does the same thing after I replaced one of the cv axles
Old Dec 29, 2010 | 10:31 AM
rcacs's Avatar
I forgot to update this post for quite some time now. I was able to cure the problem completely. The driver side control arm ball joint was completely worn out, not sure why I didnt find it earlier. I replaced both sides (pass side seemed fine) and she drives straight as an arrow now under acceleration/shifting.
Cheers!
williama
Jan 2, 2014 03:21 PM
FIGMAN
Aug 22, 2008 06:35 PM
cnyniceguy
Feb 8, 2006 04:53 PM
JSqualo621
Jan 13, 2006 03:19 PM
PATIBBY
Jan 6, 2006 06:04 AM
