trans coil pack 99 accent auto transmission
Old Feb 23, 2009 | 08:50 PM
Bailey3's Avatar
Default trans coil pack 99 accent auto transmission
Ok so I recently went to the dealership to have them check why my car was having trouble shifting properly.They said it was some kind of trans coil pack or something like that.What i need to know is where exactly its at and how to go about replacing it as in step by step or as close to it as possible.also what does it look like.Basically any and all info I could get on this and the rest of my car would be very helpful
Old Feb 24, 2009 | 03:34 AM
jsinton's Avatar
Banned
Sorry, there's no "trans coil pack". Here's some questions to help you track down the problem:
How many miles do you have?
Did you flush the transmission? If so, when, at how many miles?
What are the symptoms?
What does the dealer want to replace, and how much do they want to charge?
Did you have a trouble code scan done? If not, go to Autozone, tell them you have a "check engine" light, and note any codes.
About half the mechanics will do a good job and charge a lot of money, the other half won't do a good job, and still charge a lot of money. Better for you to answer the questions I put to you, and we'll try to fix it for free for you.
Old Feb 24, 2009 | 06:39 AM
So you want to repair your trans but you don't know what the problem is or how to fix it. That's a recipe for disaster.
First, if the trans isn't shifting right, the mechanic probably said CLUTCH pack, not COIL pack. If that's correct, that is an internal problem in the transmission and unless you have experience rebuilding transmissions, I wouldn't suggest you doing it yourself. Take it back to the mechanic and let them fix it correctly.
Old Feb 24, 2009 | 07:29 AM
zero_gravity's Avatar
Banned
and make sure they top off your headlight fluid
mikenjapan
Jul 26, 2015 02:35 AM
TheSuperPony
Jul 7, 2013 11:16 AM
bamboo
Jul 7, 2011 12:32 AM
bernd
Nov 18, 2010 09:57 PM
Stacey98Tib
Sep 30, 2006 08:41 PM
