Hyundai Azera A Hyundai like you've never seen before.
06 Azera beginning to leak oil???
Old Aug 20, 2007 | 11:54 AM
Billman's Avatar
Default 06 Azera beginning to leak oil???
My 06 Azera only has 7K miles on it and I noticed this weekend that it's beginning to leak oil. I'm getting ready to call the local dealer but before I do I wanted to ask if anyone else has had this problem?
Thanks,
Old Aug 20, 2007 | 01:27 PM
Doohickie's Avatar
Default RE: 06 Azera beginning to leak oil???
I haven't heard of it before. Make sure you get it taken care of. My first new car was a Ford Tempo that started leaking early on and I stupidly accepted the dealer's explanation that it was "normal". Don't fall for that one!
Old Aug 20, 2007 | 05:57 PM
mahout's Avatar
Did you determine the location where oil is 'leaking'? And did you check the oil drain plug is tight? The oil filter cap? These are the first things you should do before taking a trip to the dealer as it is your responsibility these are OK. In the trip to the dealer if the oil plug falls out or the oil filter cap pops off your engine will faill in short order. Yes I know this is a bit late reply but it is intended for all inexperienced drivers to protect themselves from manufacturer's denial of warranty. Forewarned is forearmed. Cheers.
Old Aug 21, 2007 | 07:52 AM
Doohickie's Avatar
If the car has been serviced by the dealer, that's THEIR responsibility to make sure they did the work right!
JL07Santa
Jan 25, 2021 02:16 PM
anonymouse
May 10, 2010 01:32 PM
ernied
Sep 28, 2009 10:18 AM
cleonescu
Jan 2, 2009 07:14 PM
tallwest
Nov 1, 2008 10:47 AM
