Emissions Monitors?
Emissions Monitors?
Would anyone happen to know what the drive cycle is for a 2006 Azera? My battery died just before inspection, replaced it, drove around 80 miles, still has 3 monitors down . Tried googling, everything says except Azera. Evap, catalyst and o2 monitors are down
First we need to know what 2 monitors are not being run.
Then we need to determine what the requirements are for the monitors to run and what prevents them from running.
As you can see there is a lot that has to be known here and you are trying to do this with one hand tied behind your back. Best to have a qualified shop do the job.
I listed 3, said that two were still down. It still has not run the catalyst and evap monitors. I asked the question because I didn't know what conditions had to be met, that's what I was asking. But thanks again, I just love the obviously you dont know what your doing take it to the dealer. Very unoriginal.
If it was all that easy , you would have fixed it by now.
There is quite a list of conditions and even a pro has to check. Even if we were able to provide the list , you don't have the equipment to verify and confirm the repair.
Sorry you feel offended, that was not intentional.
Instead of you putting out a lot of time and $$$ , some things are better left to the folks with the equip and knowledge of the system AND access to the info.
Some requirements require the fuel tank be more than half full, vehicle has to sit for X number of hours, plus a bunch of other requirements that I, just as you, would have to look up.
CharlieMin
12-24-2019 12:46 AM
CharlieMin
10-24-2019 10:39 PM
