Running into an issue on replacing A/C desiccant bag
I've installed the new A/C compressor, so then I have to replace the desiccant bag as well, I'm now trying to remove the radiator + condenser so I can gain full access to the desiccant housing cap, but then I've already unbolted the nuts of the A/C lines from the condenser, and some how I can't pull them out??? so then I was thinking to tilt the 2 things to an angle to get some room for the desiccant housing cap, and I tried 9mm, 3/8mm, 10mm hex socket, idk why it feels like it's stripping??? Could someone tell me what the exact size of the hex bolt is as well as the correct way of disconnecting the A/C lines from the condenser Not sure why Hyundai makes everything so hard
- 06 Azera Limited
- 06 Azera Limited
