2001 Elantra starter replacement
Old Mar 25, 2011 | 10:13 AM
7474's Avatar
Default 2001 Elantra starter replacement
Thanks in advance for any assistance.
PROBLEM
2001 Elantra GLS AT 180k miles
Battery has been replaced. Tested at AutoZone, battery is good, alternator is good, starter is good.
Car will start numerous times then will not start. Turn the key, get a click, no turnover. Able to be jump started without a problem. Turn car off, restart a few minutes later without a problem.
SUSPECTED SOLUTION
Recently replaced purge valve for emission problem and starter appears to be in line with the purge valve directly below? What is the easiest approach to replace the starter, above or below engine? I have read to remove air filter intake and approach that way. Seems to be a bit crowded.
Any experience would be greatly appreciated. Thanks.
lightningdan
Jan 24, 2013 11:20 AM
riebe
Apr 11, 2012 06:57 AM
jasonheise
Jun 24, 2011 04:42 PM
MACcent
Feb 5, 2009 05:02 PM
ProDrive Audi
Jun 4, 2007 10:13 PM
