2005 Elantra has bad driver's side door lock solenoid
Old Nov 30, 2007 | 09:54 AM
kargo27's Avatar
Default 2005 Elantra has bad driver's side door lock solenoid
Hello All,
I picked up a 2005 Elantra GLS I think, there were no markings on the car nor did it have an owner's manual, yesterday and it is a salvaged vehicle (flooded).
I had it checked out by two local shops and they said it was refurbished correctly. However, the driver's side power door lock doesn't work. The other 3 doors work fine. I have to manually push the lock closed and pull it open. The door key works fine. I was told at one of the local indedpendent shops that the solenoid is probably bad. I don't have a problem ordering one and fixing it myself. I've looked online this morning and can't find any diagrams on what to order. I think that I just haven't found the right online site yet.
Also, I got no key fob with this car. Is there a way to get a replacement? I'm guessing dealership has to do that. How do I know if my car has a key fob or not?
Thanks!
Karl G.
Old Nov 30, 2007 | 11:53 AM
cruiser69's Avatar
Default RE: 2005 Elantra has bad driver's side door lock solenoid
Hi Karl. Usually the dealer can run your VIN number to find out what the car came with. That way can can verify if your car came with the key fob or not and if so, program a new one for you. Because it was a flood damaged car, be prepared for electrical problems down the road. Usually the problems occur in the connectors to your wiring. Corrosion is the biggest problem. I recommend disconnecting as many connectors and harnesses as you can find, clean the connectors, apply anti corrosion grease, then reconnect. This will help make problems less likely in the future. Good luck.
Old Dec 3, 2007 | 06:12 PM
kargo27's Avatar
ORIGINAL: cruiser69
Cruiser,
Thanks for the tip. I took it in to the dealer today and they said it did come with a fob. So, I ordered two.
I did disconnect the cruise control wiring harness and it had no signs of moisture or corrosion, but it also had a nice rubber o-ring to keep out moisture.
I'll go over the connections this weekend and look for corrosion. I have some dielectric grease that I'll use on them too.
Karl
Old Dec 5, 2007 | 02:34 PM
kargo27's Avatar
Another good thing. The dealer is going to replace the cruise control and door lock assembly under warranty. The parts will be in tomorrow.
Karl
Deemyrone
Nov 14, 2014 10:32 AM
nateb22
Mar 14, 2011 07:46 PM
Matt_FSU'13
Nov 19, 2010 07:40 PM
richedie
Dec 30, 2008 09:12 AM
FIGMAN
Aug 22, 2008 06:35 PM
