2017 Elantra Eco 1.4T pulled injector harness pins
Old Jan 28, 2023 | 11:54 AM
  #11
Kaff's Avatar
Originally Posted by hanky
Two things that would help,
Can you determine just where the other plug is that does not have the wires messed up? They could be the same colors, are they?
The wires in your pix, there appear to be 10 of them . Is this correct, AND can you trace some of them and tell us where the other end is or connected to?
A wiring diagram will be helpful , but wire color alone does not always agree with a diagram.
If possible you might consider checking with a salvage yard for a vehicle like yours to either get some idea of where the wires go or even just get the plug with wires still in it..
There are 11 pins.
the colours on the male connector do not match those on the female.
I'm in west africa and don't have access to junk yards with such inventory.
the dealerships here only sell and service vehicles built for Sub-Saharan and africa, as a result they do not have a 1.4L engine in any of those.
My only hope would be to find another Eco model which has proven to be nearly impossible here.
Old Jan 28, 2023 | 02:06 PM
  #12
Will try to see what we can find.
Old Jan 29, 2023 | 12:55 PM
  #13
If you expect to ever get this thing running you are going to have to do some real wire tracing.
I managed to locate a diagram, but it is pretty difficult to read the very fine print.
What I need from you is to tell me where which color wire goes where from both ends from the plug that still has the wires in it and the wires you posted in the pix.THEN,,,,, I should be able to tell you which to connect to which.
This will be a challenge for both of us , but I believe we can get this straightened out If we stick with it.
This will take some real effort from you and I don't know just how much you want to put into this.
Please let me know, thanks.
Make sure you make a diagram of what you trace with the colors you have OK , thanks.
MercuryForever
Oct 2, 2021 02:11 AM
Ron Sheryl Hoak
Jan 11, 2020 12:48 AM
Mido2001
Nov 26, 2018 01:18 PM
Prince Edward
Jan 5, 2017 12:43 PM
mark0006
Jul 27, 2016 11:03 PM
