Another transmission problem
Old 02-25-2010, 07:43 PM
Bunklash's Avatar
Default Another transmission problem
Doing a web search I've found the Elantra transmissions seem to have an awful lot of problems, but I'm finding no solutions. Half the time my 2000) won't shift from 3rd to 4th. Stop the engine, re-start and it's OK again. I also notice the RPM's seem to vary slightly while cruising at the same speed. I had codes read, they are 0743, 0745, 0765, and 1624. The first three are tranny control solenoids, the last is cooling fan circuit. It started a day after I drained and refilled tranny fluid (Hyundai brand).
Can anybody tell me anything I can check other than taking it to a shop. Can I get at the solenoids through the drain pan? I'm a competent mechanic, not afraid to tear into anything, but could use some guidance on where to start.
Thanks.
Old 02-26-2010, 11:19 AM
samkent's Avatar
Another? I haven’t heard of anything unusual from the Elantra tranny. My daughter is driving my 99 (90K) and no problems.
But I will admit that I’m a bit afraid of messing with trannies. I delude myself into thinking if it ain’t giving me problems, why chance it. But that’s only with trannies. Everything else I side on a more proactive approach.
Maybe it’s my experience with my old Dodge minivan. I changed the fluid and filter and then it started giving me problems. Logic says it was just it’s time to fail. Heck they all failed.
Old 03-05-2010, 09:52 PM
Bunklash's Avatar
Anybody???
Old 03-06-2010, 09:19 PM
Thanks.
Best to use HI-SCAN' Actuation test to verify solenoid operation... TSB calls out verify internal A/T wire harness not open/short.. You have bottom pan trans, so you need to remove pan, and valve body, as solenoids is on top of valve body towards the case
Did you happen to find remnants of a TORRINGTON roller brg in the oil pan ?
Old 03-07-2010, 01:02 PM
Bunklash's Avatar
Thanks for the reply sbr711. I spoke to a transmission tech I found on Craigslist, he was very helpful. I haven't had time to do any more troubleshooting, but given the nature of the symptoms, he's convinced the internal mechanical portion is OK, that it's most likely an electrical connection problem. I tend to agree, and hope he's right. I can get a used TCM for about $60 off EBay. Meanwhile, when I get time, I'm going to check out all the wiring and connectors. The main connector plug to the tranny is falling apart..... brittle from heat. I'm determined to find this problem. I'll keep you posted.
Old 03-07-2010, 08:21 PM
Hytech's Avatar
With those codes check the connector going to the trans. if it is ok then you probably have a bad ground inside the trans. it's been a few years sence I have worked on older elantras regularly but when I used to run into multiple solinoid codes on these transmisions I always found that the ground connection on top of the valve body was loose.
Old 03-07-2010, 08:26 PM
Hytech's Avatar
I just saw the bottom of sbr711s post. If you find roller bearings in the pan pull the side cover and pull of the end clutch. If you see it is from that thrust bearing under the end clutch you can replace it easily it takes less than an hour to do in the car.
Old 03-08-2010, 05:06 PM
Bunklash's Avatar
Thanks guys.
sbr711, No there were no bearings in the pan. All I found was a light coating of "dust" clinging to the bottom of the pan. No accumulation of metal on the magnets. More reason for me to believe what Hytek is confirming about an electrical problem.
Hyteck, sounds like what the guy from Craigslist told me. The ground wire in the tranny? Do I need to drop the valve body to get at it? Just hope I get time to work on it soon, maybe this weekend.
Sure appreciate the help,
Bunky jones
Old 03-09-2010, 06:13 AM
Hytech's Avatar
Yes it is on top of the valve body. PM me your email address and I'll send you a .pdf file with a step by step diagnosis and repair.
Old 03-09-2010, 06:57 PM
Bunklash's Avatar
You betcha hytech, on it's way
THANK YOU!
Quick Reply: Another transmission problem
