Anyone still have a '91/92/93/94/95 or 96/97/98?
If you still have 91, 92, 93, 94, 95 (gen 1) or 96 or 97 or 98 (the gen 2), could you let me know?
I was hoping someone could look at their OBD-I port for me on their 91-95 and let me know which pins are populated in that 12-pin OBD port. And what the wire colors and tracer stripes are on each wired pin.
Or, if you have a 96-98, could you look at that 16-pin OBD-II port, and let me know which pins are populated?
The 12-pin should look like this:
There should be two slots on the top row separated by 2 empty spaces then 3 more slots, and have 6 slots on the bottom row.
1 2 empty slot empty slot 3 4 5
6 7 8 9 10 11 12
Thanks.
6 7 8 9 10 11 12
Thanks.
Correction, the 12-pin OBD-I connector should look like this:
5 4 empty slot empty slot 3 2 1
12 11 10 9 8 7 6
There should be two terminals on the top row separated by 2 empty spaces then 3 more terminals, and have 6 terminals on the bottom row. (Pins 10 & 9 should be under the 2 empty slots, respectively, and pin 8 should be under pin 3 and pin 7 should be under pin 2 and pin 6 should be under pin 1. I say this in case the forum editor tool looses the formatting I keyed in.)
12 11 10 9 8 7 6
