Changing Front Breaks??
Old Jul 18, 2007 | 08:37 PM
raleigh's Avatar
Default Changing Front Breaks??
Hi everyone,
I am looking to try and change my front breaks, pads and rotors, on an old 1997 Elantra and I could use any advice as to how to proceed!
Thanks a Lot
Raleigh
Old Jul 31, 2007 | 08:48 AM
mechanic98's Avatar
Default RE: Changing Front Breaks??
well, get a haynes or chilton repair manual for the vehicle. Apply theE-brake... jack up one side of vehicle, while placing a jackstand, or block beneeth it... Then take off the tire, take off the two bolts that hold the caliper on the rotor. Take off the pads from the caliper. You will need a C-Clamp to push the caliper piston back into the caliper. Clean the area where the pads touch the caliper with a wire brush. Replace the pads... The rotors either will just pop off, with a little hit of a rubber Mallet hammer. Or it will be held on by bolts, you will see this when taking off... Then just replace in the order that you took off... and then do the other side the same way. Hope this helps a little...
mawoet
Jul 3, 2010 03:51 AM
JayTye4k
Mar 29, 2010 06:47 PM
prezman62
Jun 10, 2009 09:40 PM
SheHateMe
Mar 28, 2009 06:07 PM
redneckidiotf1
Mar 7, 2006 09:33 AM
