Dropping and Changing tranmission on 01
Old Oct 3, 2008 | 11:17 AM
snvts82's Avatar
Default Dropping and Changing tranmission on 01
My transmission crapped out on me on my 01 automatic elantra. how hard is it to drop and swap these. I have done it a couple times before but never on a front wheel drive car.is there anything the average garage wrench turner needs to look out for, thanks
Old Oct 3, 2008 | 01:09 PM
ken99's Avatar
Default RE: Dropping and Changing tranmission on 01
I suggest you review this thread by another forum member that just did a good job of documenting a clutch replace on an Elantra:
https://www.hyundaiforum.com/m_16043/tm.htm
The basic process is the same regardless of whether it is an automatic or manual transmission. One of the first steps that is different will be to remove the bottom bell housing cover and unbolt the torque converter from the flex plate on the back of the engine, and you will have cooler lines to disconnect that the manual does not have. After that, the process will be pretty much the same. You should also establish a user account on the Hyundai service site (http://www.hmaservice.com/) and read up on the "Shop" documentation regarding this repair.
Moordoom
Dec 5, 2017 11:51 AM
MikeSTL
May 19, 2013 07:24 PM
ScubaPaul
Aug 30, 2010 06:59 PM
sujey2304
May 25, 2009 04:07 AM
Taz
Jul 18, 2006 06:34 PM
