Help!!
I have a 99 Elantra (5 speed). One day it started sputtering at high speeds then gradually got worse. It now bogs down upon takeoff and stalls at lights, etc. It now just started reving up high after it sputters.
I'm thinking maybe a clogged fuel line that's flashing??
I already changed all the plugs and wires so I ruled that out. I doubt it's the Coil Pack. It seems to be a fuel problem. Anyone ever ran into something similar?
Can anyone please help me???
Thank you
Thank you
I have a '98 Elantra and had a problem with the revs being all over the place, also shutting off when at a light. I took it to a autoparts store where it could be checked for errors by computer. Turns out I had a faulty TPS, Throttle Position Sensor. The sensor was $50.
I replaced it and now she runs like a top. Advanced Auto or AutoZone will check your car for free for errors. Other than perhaps trying to run some high test (premium unleaded fuel) from a name brand like Shell or Conoco station.
My only guess is perhaps last time before the issue started, you filled up at a place where the fuel was lowest and some debris from the bottom of the refilling tank was introduced to your system.
Best of luck.
Best of luck.
Where do I look next?
It's a bad Purge Valve Sensor Code. The Purge Valve is bad. Will a bad purge valve effect the way a car runs? Could it have anything to do with the way the car is missing in idle?
