HELP...code P0340
Old Dec 27, 2010 | 02:47 PM
danb08's Avatar
Default HELP...code P0340
Okay so on my 2002 hyundai elantra gls, I have a code P0340 camshaft position sensor circuit malfunction bank 1. Camshaft sensor is brand new. Checked all voltage and whatnot between pcm and sensor. Everything is good. I have swapped out several pcm and i still get same code. Resistance in crankshaft sensor is between the resistance numbers. I have played around with the timing and even retimed the crank to the cam tdc. cam gears notches are at 2:30 o clock like i have read. What could possibly be the problem??? PLEASE HELP ME OUT!!
THanks in advanced.
Scypheroth
Feb 3, 2015 01:54 PM
mikeyrod
Jul 10, 2014 09:49 AM
JerzyG
Jan 3, 2013 12:06 PM
tedallen
Oct 17, 2012 11:09 AM
mybroketib
Nov 29, 2010 01:49 PM
