Primary Resistance on Coil ????????
Old Jan 3, 2008 | 04:55 PM
AManiscalco2007's Avatar
Default Primary Resistance on Coil ????????
Hey Experts,
I have another question for you. In my manual it is telling me that the primary windingsresistance in the coil should be 0.45 to 0.55 ohms. I tested it using a digital voltmeter on the 200 ohm setting and got 1.1 ohm on both. Does this mean that the coil is no good?
Old Jan 3, 2008 | 10:31 PM
madindian1's Avatar
Default RE: Primary Resistance on Coil ????????
well is the car running? according to the specs. it would seem as if the coil is no good but i say if it's working that would tell me that the coil is good. sometimes those specs tell you what to look for when diagnosing a problem, if you had came up with a number like 2.5 ohms then you know you have a problem.
Old Jan 5, 2008 | 07:26 AM
Yeah, it was runninhg but loping at idle and throughout driving. I visually inspected the coil pack after I removed it from the car. Looking in the plug posts on the coil pack I noticed that #1 cylinders's post internally was corroded very badly. The rest of them were fine.. I am just gonna replace the coil pack. Thanks.
larry12s
Aug 18, 2012 12:47 PM
Bailey3
Feb 24, 2009 07:29 AM
AManiscalco2007
Jan 6, 2008 07:07 AM
Stacey98Tib
Sep 30, 2006 08:41 PM
