Removing trunk lock
Old Oct 12, 2017 | 12:02 PM
roelantra's Avatar
Default Removing trunk lock
2005 Elantra 4-door
The previous owner rekeyed the trunk lock, but there's no key, and I can open it only with the latch on the driver's side floor. I want to rekey it for my ignition key. How do I remove the lock?
Old Oct 12, 2017 | 07:57 PM
avisitor's Avatar
Open trunk and access rear side of lock
There should be a "C" clip
Remove clip and lock should come apart.
Unless you have a different lock
Old Oct 15, 2017 | 11:46 AM
roelantra's Avatar
No, not a diff lock, I think. Just want to rekey it to my ignition key. Many thanks! :-)
Old Oct 16, 2017 | 12:29 PM
There is no way to rekey the lock. You replace it.
Old Oct 16, 2017 | 06:34 PM
avisitor's Avatar
Any locksmith can re-key the lock.
But, probably easier to buy new lock.
Old Oct 16, 2017 | 10:25 PM
roelantra's Avatar
One key for both is my preference, but I'm open to a new lock. The cylinder is removable, so I'll talk to my locksmith and compare prices. Thanks, guys.
Old Nov 5, 2017 | 01:25 PM
roelantra's Avatar
Oops, I've gone in a few times with a flashlight, and there's no C-clip. I still can't figure how it comes out.
Old Nov 6, 2017 | 07:09 AM
avisitor's Avatar
If it is a lock cylinder there may be a nut near the trunk wall
Look at lock from outside.
The cylinder could be threaded and a nut threaded on to hold it against the trunk hood
OR
Sometimes there is trim or a panel that must be removed to access the trunk lock
Once removed then you should be able to see the inside of the lock
Three nuts should be holding the lock in place. Remove with socket set
Lock should come out
Check out youtube
They might have a video with your car???
Old Dec 10, 2019 | 07:30 AM
DonaldGrace's Avatar
These nuts can be replaced by own without taking help from a locksmith.
Old Dec 10, 2019 | 06:08 PM
avisitor's Avatar
Did you read the thread or just skip to the end?
The OP wanted to re-key the trunk lock.
He just wanted some help to remove the trunk lock.
treedrat
Apr 20, 2017 05:36 PM
dandianne
Apr 30, 2011 07:03 PM
Matt_FSU'13
Nov 19, 2010 07:40 PM
zero_gravity
Apr 8, 2009 08:52 AM
hopoffbaby
Jan 7, 2006 05:49 PM
