ESC Going off
Has anyone had a problem with the ESC going off. I tried to push the button, but it would not go back on. When I turned the engine off then back on it was okay.
Seems to be happening often. Help! 2009 Touring. |
Have not had a problem. Is it possible that the switch is bad, or maybe a loose connection?
There is a recall on the brake light switch where one of the symptoms is what you are describing. However, the Touring is not on the recall list. But the problem could be the same. Does your cruise control still work when the light is on?
(Post 37977)
There is a recall on the brake light switch where one of the sysptoms is whet you are describing. However, the Touring is no on the recall list. But the problem could be the same. Does your cruise control still work when the light is on?
one of my friend have got similar porblem on santa fee and dealer have change a switch on brake pedal i also know if you have electric power problem like bad alternator some computor in car will be turn off to keep power for more important computeur |
Originally Posted by tub
(Post 38016)
no cruise on touring in usa
Hyundai Motors Elantra Touring Pricing
(Post 38016)
(Post 37977)
I will check next time to see if the cruise will work.
Yes, I have cruise control on my Touring. |
Originally Posted by DrDemento
(Post 38026)
Funny thing happened to me today. I came home after a 250 mile trip and when I pulled into my garage, the ESC light was on and would not shut off.
I've been reading on different Hyundai sights and with some of there other models they have the same problem and the dealership changes the brake switch assembly, apparently it is a common problem. |
Thanks for the info. The Cruise control worked fine when this happened.
This happens to me from time to time, too. Usually after I've taken a corner a bit more aggressively than I should have, or I've hit the breaks pretty hard. The only solution I've discovered is to turn the car off then on.
N.B. I have a 2009 Elantra Touring 5-speed. |
