ESC Going off
Old Jun 18, 2011 | 09:55 AM
DrDemento's Avatar
Default ESC Going off
Has anyone had a problem with the ESC going off. I tried to push the button, but it would not go back on. When I turned the engine off then back on it was okay.
Seems to be happening often.
Help!
2009 Touring.
Old Jun 19, 2011 | 10:34 AM
touring10's Avatar
Have not had a problem. Is it possible that the switch is bad, or maybe a loose connection?
Old Jun 19, 2011 | 12:10 PM
There is a recall on the brake light switch where one of the symptoms is what you are describing. However, the Touring is not on the recall list. But the problem could be the same. Does your cruise control still work when the light is on?
Old Jun 21, 2011 | 04:30 PM
tub's Avatar
tub
There is a recall on the brake light switch where one of the sysptoms is whet you are describing. However, the Touring is no on the recall list. But the problem could be the same. Does your cruise control still work when the light is on?
no cruise on touring in usa
one of my friend have got similar porblem on santa fee and dealer have change a switch on brake pedal i also know if you have electric power problem like bad alternator some computor in car will be turn off to keep power for more important computeur
Old Jun 21, 2011 | 05:54 PM
What are you talking about? Cruise is available on the Touring in the US:
Hyundai Motors Elantra Touring Pricing
Which is exacly what I said above:
Old Jun 22, 2011 | 06:38 AM
DrDemento's Avatar
I will check next time to see if the cruise will work.
Yes, I have cruise control on my Touring.
Old Jun 22, 2011 | 07:08 AM
tub's Avatar
tub
k i have see a post about no cruise on touring in usa is good if hyundai decide to add cruise on touring
Old Jun 22, 2011 | 12:44 PM
touring10's Avatar
Funny thing happened to me today. I came home after a 250 mile trip and when I pulled into my garage, the ESC light was on and would not shut off.
I've been reading on different Hyundai sights and with some of there other models they have the same problem and the dealership changes the brake switch assembly, apparently it is a common problem.
Old Jun 23, 2011 | 08:22 AM
DrDemento's Avatar
Thanks for the info. The Cruise control worked fine when this happened.
Old Jun 23, 2011 | 12:25 PM
dullgeek's Avatar
This happens to me from time to time, too. Usually after I've taken a corner a bit more aggressively than I should have, or I've hit the breaks pretty hard. The only solution I've discovered is to turn the car off then on.
N.B. I have a 2009 Elantra Touring 5-speed.
