Fuel cap Cover - does it pop open?
Old Oct 20, 2010 | 07:41 PM
  #31
zielritter's Avatar
If it's popping open 1/2" then it's working normally. It isn't designed to open all the way.
The people with a problem have doors that don't move at all (or very little). The can't grip the edge with their fingers and need to use something like the key to stick in the slot and pry it open.
Exactly. I pull the release and the door doesn't even clear the edge of the panel.
Old Nov 1, 2010 | 05:31 PM
  #32
DrDemento's Avatar
As stated the door was completely replaced. I would assume the spring is part of the door.
Old Nov 2, 2010 | 02:56 PM
  #33
originalfred66a's Avatar
Default Make sure the door is on track
I took my 2010 Hyundai Elantra Touring to the dealer because the gas cap door cover was sticking and would not pop open. The mechanic opened it and pulled up on it a little. He said they frequently get off track and need a little adjustment to get back in the groove.
This was NOT the real problem. There is a "V" shape spring attached to the arm of the door. It is behind the arm, you cannot see it, and you can only reach it if you take off the gas cap. If you can bend the spring out with your finger, the door will pop open properly.
Here is the recall notice that shows where the spring is located.
http://www.myhyundaiforums.com/11-01-012.pdf
Last edited by originalfred66a; May 10, 2011 at 09:47 AM. Reason: correct wrong information
Old Feb 21, 2011 | 07:08 PM
  #34
markmayle's Avatar
Default Another gas door problem
My ET 2009 gas door also stuck. Had the dealer look at it when I had it in for another warranty repair. They fixed it, but first time at the gas station it stuck again.
Next time it was in for another issue, I had them look at it again. This time they said that they needed to replace the entire gas door. It took them a week to get the part, and another to paint it (the doors come in one color). During that time I was able to drive a nice loaner Santa Fe
After I got the car back it has worked great ever since.
Old Apr 15, 2011 | 01:40 PM
  #35
dadepetro's Avatar
Default Replace fuel door?
Does anyone know where I can buy a new fuel door for my 2010 Elantra? I called the dealer and they want almost $200 and that's unpainted.
Old Apr 15, 2011 | 02:02 PM
  #36
Junkyard or here (if you know the part number): Hyundai Parts Online Parts & Accessories Catalog
Old Apr 16, 2011 | 09:39 PM
  #37
Rontier's Avatar
my wife just told me about this fuel door not opening today ??
but she said she would just keep using the key to open the door it was no big deal to her!!
So all I can say is it's her car and leave it to her!!
Austin TX
Old Apr 17, 2011 | 01:33 PM
  #38
nimbus's Avatar
I had my ET in to the dealer this past week for its 7500 mile check-up. The service dept guy told me there were two "campaigns" issued for my model (a 2010). One was something to reinforce the struts, and the other was a fix for the fuel door. Finally, my fuel door pops open as it should. All done under warranty, of course. You all might want to ask your service dept rep about these campaigns.
PS--I think the word, campaign, here is too funny. Sure sounds better than TSB or recall.
Old Apr 18, 2011 | 05:57 PM
  #39
HEHEHEHEEEE..... Use your finger to bend the "V" shaped door spring so it pops the door a bit more open.. already been done to Sonata in past, common knowledge.
They come out with a cheezie recall to stick a piece of dense foam on the "V" spring to provide a bit more rebound when door released with Elantra Tour and their premier EQUUS.. cant wait to see how long it last, till weather gets to the foam and kills it..
Kocho
Apr 17, 2012 10:21 PM
toomanyhobbies
Dec 22, 2010 09:33 AM
Cervantes
Sep 27, 2010 09:33 PM
Vanga
Aug 30, 2010 07:36 PM
drummerfromhell
Feb 3, 2006 09:56 AM
