2004 Elantra antenna replacement
I want to replace the manual antenna in my wifes car with an electric one I recently got; how do I connect power to the new one? There is a connection fairly close but it's not long enough to reach when the antenna is in place. Can you get an extension lead for joining them?
Longer antenna lead in wires are available, but not sure where you can obtain one.
Did this antenna come with any instructions for installation?
The installation should consider a fused power source through a switch to the antenna motor. Does it, or, is it relying on the radio on/off switch which by itself is not made to handle a power requirement like an antenna motor.
dragan322
Aug 31, 2022 10:34 AM
dwfan
Jan 5, 2009 06:50 PM
