Hyundai Forum Help & Suggestion Center Need help with HF? Ask! Have a suggestion to better HF? Tell us here..
valve stem - 2017 Sinata
Old Jan 12, 2020 | 01:12 PM
wpoints's Avatar
Default valve stem - 2017 Sinata
I have a leaky valve stem on my right front tire. My tire sensor is working properly. Can someone tell me if the valve stem is connected or part of the sensor? Many thanks for any info.
Old Jan 12, 2020 | 04:26 PM
The majority of the time the stem is part of the sensor. Some older sensors were mounted to the center of the wheel rim.
If it is leaking out the opening where the air goes in, a simple valve cap/tool can tighten the core if it is loose, otherwise it may need to be replaced.
Use only plastic valve caps to prevent corrosion from dissimilar metals.
Kevin Sheffield
10
Oct 8, 2018 02:49 PM
Dman_2133
Sep 10, 2017 11:21 PM
nufo
Jan 30, 2017 10:45 PM
mike26
Apr 14, 2016 08:58 PM
tiburon801
Mar 25, 2009 02:35 PM
