2001 Santa Fe Fog Lamp replacement?
Old Jan 11, 2009 | 11:48 AM
tkagain's Avatar
Default 2001 Santa Fe Fog Lamp replacement?
How do you replace the bulbs in the fog lamps on a 2001 Santa Fe?
Old Jan 11, 2009 | 12:05 PM
jsinton's Avatar
Banned
Default RE: 2001 Santa Fe Fog Lamp replacement?
2001 > G 2.4 DOHC > Body Electrical System REPLACEMENT OF LAMPSHEAD LAMP/TURN SIGNAL LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Remove the head lamp mounting bolts and remove the head lamp assembly.[/align]3.Installation is the reverse of removal.[/align]FRONT FOG LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Remove the head lamp mounting bolts and remove the head lamp assembly.[/align]3.Remove the screws in the front bumper cover.[/align]4.Raise the vehicle then remove the screws holding the front bumper and the front wheel guard.[/align]5.Remove the front fog lamp from the bumper cover.[/align]6.Installation is the reverse of removal.[/align]REAR COMBINATION LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Open the tailgate and loosen the screws holding the rear combination lamp.[/align]3.Disconnect the connector and remove the lamp assembly.[/align]4.Installation is the reverse of removal.[/align]CENTER HIGH MOUNTED STOP LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach 2 blanking covers on both sides of the lamp.[/align]3.Remove the two mounting screws.[/align]1.Disconnect the connector and then remove the lamp assembly.[/align]2.Installation is the reverse of removal.[/align]LICENSE PLATE LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Remove the mounting bolt, and disconnect the lamp connector.[/align]3.Installation is the reverse of removal.[/align]MAP LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach the map lamp lens.[/align]1.Detach the lamp assembly from the headlining after removing the screws.[/align]2.Disconnect the connector from the roof harness.[/align]3.Installation is the reverse of removal.[/align]ROOM LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach the room lamp lens.[/align]1.Detach the lamp assembly from the headlining after removing the screws.[/align]2.Disconnect the connector from the roof harness.[/align]3.Installation is the reverse of removal.[/align]LUGGAGE LAMP[/align]1.Using a flat-bladed screwdriver detach the luggage lamp lens.[/align]2.Detach the lamp assembly from the headlining after removing the screws.[/align]REPLACEMENT OF LAMPSHEAD LAMP/TURN SIGNAL LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Remove the head lamp mounting bolts and remove the head lamp assembly.[/align]3.Installation is the reverse of removal.[/align]FRONT FOG LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Remove the head lamp mounting bolts and remove the head lamp assembly.[/align]3.Remove the screws in the front bumper cover.[/align]4.Raise the vehicle then remove the screws holding the front bumper and the front wheel guard.[/align]5.Remove the front fog lamp from the bumper cover.[/align]6.Installation is the reverse of removal.[/align]REAR COMBINATION LAMP[/align]1.Disconnect the negative battery terminal.[/align]2.Open the tailgate and loosen the screws holding the rear combination lamp.[/align]3.Disconnect the connector and remove the lamp assembly.[/align]4.Installation is the reverse of removal.[/align]CENTER HIGH MOUNTED STOP LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach 2 blanking covers on both sides of the lamp.[/align]3.Remove the two mounting screws.[/align]1.Disconnect the connector and then remove the lamp assembly.[/align]2.Installation is the reverse of removal.[/align]LICENSE PLATE LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Remove the mounting bolt, and disconnect the lamp connector.[/align]3.Installation is the reverse of removal.[/align]MAP LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach the map lamp lens.[/align]1.Detach the lamp assembly from the headlining after removing the screws.[/align]2.Disconnect the connector from the roof harness.[/align]3.Installation is the reverse of removal.[/align]ROOM LAMP[/align]1.Disconnect the battery negative terminal.[/align]2.Using a flat-bladed screwdriver detach the room lamp lens.[/align]1.Detach the lamp assembly from the headlining after removing the screws.[/align]2.Disconnect the connector from the roof harness.[/align]3.Installation is the reverse of removal.[/align]LUGGAGE LAMP[/align]1.Using a flat-bladed screwdriver detach the luggage lamp lens.[/align]2.Detach the lamp assembly from the headlining after removing the screws.[/align] [/align] findme('); findme('); findme('); [align=left] [/align]
ken9949
Sep 3, 2012 08:19 PM
yoshitei
Oct 18, 2008 02:50 PM
slarty42
Nov 7, 2007 02:37 PM
shad0w
Jun 27, 2007 01:29 PM
askem
Feb 26, 2006 12:52 PM
