2004 Santa Fae 2.7 Timing Issue
Old Dec 4, 2017 | 08:52 PM
dominionitsolutions's Avatar
Default 2004 Santa Fae 2.7 Timing Issue
I had a motor mount break and while it was torn down I noticed the timing belt was wearing. I tryed lining up the timing marks but the starter just clicks now when I try to start it. I notice the cams springs back with pressure and sometimes goes past the timing mark. The marks for both cams are pretty easy to see, however I am not real sure about the crankshaft. Why is the crankshaft so hard to turn? Thanks for all your help.
Old Dec 5, 2017 | 07:44 AM
avisitor's Avatar
Crankshaft turns the pistons.
When pistons are on compression stroke, it is tough to turn the crankshaft
Try taking the spark plugs out. That should make it a little easier.
Also when trying to turn the crankshaft, should try using the crankshaft bolt with a socket wrench
Good luck
zerosoma
Jun 21, 2012 09:37 PM
jalexa101
Jun 27, 2011 06:49 PM
sjjaco1
Jan 31, 2010 11:39 PM
jj_protege
Dec 18, 2008 09:04 PM
mbred0609
Jan 13, 2008 12:36 AM
