2008 santa Fe foglight bulb replacement
Old 11-24-2008, 10:33 AM
DMS4420's Avatar
Default 2008 santa Fe foglight bulb replacement
How do you replace the fog light bulb on a 2008 Santa Fe? What is the bulb number (so I can purchase it)?
Old 11-24-2008, 09:38 PM
ken99's Avatar
Default RE: 2008 santa Fe foglight bulb replacement
REPLACEMENT
1.Disconnect the negative (-) battery terminal.[/align]
2.Remove the front side cover screw.[/align]
3.Remove the front fog lamp assembly (A) after loosening screws (4EA).[/align]
4.Installation is the reverse of removal.[/align]
Page 6-31 of the owners manual indicates a 27 watt halogen with a PG13 base. That translates to type 880 halogen bulb. However, the PG13 base on the 880 is straight and the bulb in the diagramn has a 90 degree bend in the base. That would be a PGJ13 base on a type 881 bulb. You might want to pull an existing bulb out first to make sure. If the harness has enough play in it, either may work just fine.
Gordy Klug
12-26-2023 05:14 AM
steinr98
09-18-2012 09:43 PM
madmongodog
05-25-2010 06:59 PM
bodman75
07-17-2007 10:43 PM
Michaels10
05-03-2007 11:29 PM
Quick Reply: 2008 santa Fe foglight bulb replacement
