2011 Santa Fe blend door broken
Old Dec 14, 2017 | 04:58 PM
Christo's Avatar
Default 2011 Santa Fe blend door broken
Hi.
Does any one know how to replace blend door, not the actuator?
Thanks
Christo
Old Feb 8, 2020 | 01:30 PM
archiecat's Avatar
This is for a dual control hvac rhd model passenger side. Remove glovebox. Remove tray underneath that conceals blower motor. Remove duct for footwell heating (one screw attaches to blower motor). Remove actuator, three screws. Use drill to cut hole big enough to insert hacksaw blade into heater box. Cut hole big enough to be able to remove broken mixer flap. This will mean cutting out a triangular section which allows the spindle of the mixer flap to be removed. Remove broken mixer flap and replace. Use two pack epoxy to replace triangular section that has been cut out. Then try to work out what caused the flap to break in the first place.
My latest theory is that the actuator is faulty and sometimes goes beyond its stops, It tries to force the mixer flap to move further than it can and breaks the spindle of the flap.
This video for a Peugeot 407 will give an idea
2006Sonata250K
Dec 28, 2020 04:33 PM
scj6771
Oct 14, 2018 01:00 PM
riebe
Jul 23, 2012 02:10 PM
NC10735285
Feb 25, 2012 07:12 AM
fuelman
Feb 5, 2009 09:24 PM
