2012 Santa Fe Door Lock Relay Location
My mom's 2012 Hyundai Santa Fe will not power lock. I can manually lock all four passenger doors and the driver's side door with my key. However there is no way to lock the trunk.
Locking the doors with a key fob gives a clicking noise but does nothing else. If I press the lock button on the driver's side and front passenger door panel, nothing happens. The doors also do not automatically lock when the gear is put into drive.
Oddly enough the car unlocks fine! Unlocks with the keyfob, panel buttons and when gear is in park.
I changed out the door lock fuse but same issue. From another thread, a poster mentioned replacing the door lock relay. Infact, the problem can be tested by switching the unlock relay and lock relay.
Only problem is I cannot find where the door lock relay is located. I believe it's suppose to be behind the fuse box but I can't figure it out. Can anyone help with a manual, tutorial or video? Google isn't helping much with my specific issue. Thank you in advance!
It sounds like there is a broken wire/connection in the system. I would start with checking the driver's side door switch and the wires that come from the driver's door to the door pillar where the wires flex every time the door is opened/closed.. May be more than you want to get involved in.
Matter switch needed replacing anyhow, back windows were intermittent. I did find that there is a lock relay. Ordered that and hoping that will do the job.
I had that issue yrs ago with a 06 Sportage EX.. Left the driver window down just enough for the panel to get good and wet during a rain storm.. The passenger side window would not go up or down.. First thought was window motor.. After testing it and it was fine. I went and pulled the master panel on the driver door.. Lots of corrosion, replaced and issue was solved.
Yeah poor design I would say. If you are in drive through during rain storm, controls getting soaked. Anyway the issue isn't with the master switch it's the relay for the lock. Took it to local mechanic, said it's the fuse panel and the relay wasn't serviceable so it would be 4k. Come to find out it is, just difficult. Waiting for part. I'll post if successful
There's been plenty of other issues with this car since so the door lock issue wasn't a priority anymore. I'm curious if you found the lock relays or if you were able to get this fixed!
