2017 Santa Fe Sport - Driver Side Daytime Lights Stopped Working
Old Dec 4, 2020 | 04:37 PM
winnipegCar's Avatar
Default 2017 Santa Fe Sport - Driver Side Daytime Lights Stopped Working
My driver side daytime running lights stopped working.
Kindly please let me know which part I need to get and how to switch that part.
Any guidance would be helpful.
Thanks!!
Old Dec 5, 2020 | 02:28 PM
It would not be wise to suggest replacing anything until/unless we did a few checks.
On that note, do the headlights themselves work normally, if so then that would rule out the lamp for that side.
On the other hand, if the lamp on the driver's side does not work at all , newer vehicles have fuses for each lamp . So I would suggest you check the fuses for that..
In some of the owner's manuals it will explain which fuse protects what and usually has a diagram of the panel. That would save a lot of time and pinpointing the fuse for you. If the fuses are good , the lamp may require replacement.
HankusLA
Apr 24, 2020 07:47 AM
rjh1
Nov 12, 2018 02:30 PM
SkyyKorat
Jun 27, 2017 09:28 PM
Ficus83
Dec 2, 2016 09:22 PM
Geoff
Jul 22, 2005 11:49 PM
