Code P0441 2007 Santa Fe 2.7L
Old Nov 30, 2013 | 09:25 AM
  #11
Erichshonda's Avatar
Originally Posted by 07SantaFeGLS
I'm the original owner of an '07 Santa Fe GLS with 102K miles. Last weekend, my Check Engine light came on for the first time. Had it read at Auto Zone. It is P0441. Sounds like it could be time for a new purge control valve.
Is there a way to test this valve to know for sure that this is the culprit?
Thanks in advance!
Ryan
Yes, the valve is normally closed until commanded from ECM. You shouldn't be able to blow through it when tested. You can also bench test it with jumper leads connected to battery( be careful) with power supplied the valve opens, when power is released the valve slams shut from the spring that's inside. Also when replacing make sure the arrow points toward vacuum source ( intake)
Bfiz84
Jun 4, 2015 12:24 PM
Hawqis1
Apr 9, 2014 10:26 PM
blackbox19
Aug 6, 2010 09:59 PM
nrshw9
May 6, 2010 05:15 PM
