Deep engine noise in 2010 Sante Fe
Old 02-27-2012, 10:44 AM
Gary Haupt's Avatar
Default Deep engine noise in 2010 Sante Fe
Good day..we live in Northern BC and are having issues with our new to us, 2010 Santa Fe. 20,000k's.
We do not have a Hyundai shop within 8 hours so we use a Hyundai approved Honda dealership in Terrace.
The problem: on a cold start, it is making what I can only describe as a very deep grumbling sound lasting 15-20 seconds. Honda feller suggests noisy valve train.
Any input would be great.
Gary
Old 02-27-2012, 12:35 PM
How cold is it there and what weight oil are you using?
Old 02-28-2012, 10:21 AM
Gary Haupt's Avatar
It has dropped to minus 30C and in truth, I don't what weight oil is in. It was serviced for winter at the Honda shop in Prince George, where purchased in November.
For interest of readers...
Kitimat, BC, Canada - Google Maps
Gary Haupt
Old 02-28-2012, 10:35 AM
The oil may be too thick. -30C is cold. I'd suggest nothing thicker than 5w20. 0w20 if it's going to be that cold most of the time.
Do you have a block heater?
Old 02-29-2012, 10:48 AM
Gary Haupt's Avatar
HHmmm...okay NoveR...I will check on the oil weight presently in and will also investigate a block heater installation. In your opinion...is damage being incurred as things are now?
Gary Haupt
Old 02-29-2012, 10:58 AM
If the noise is from a lack of oil, yes, there would be damage. Is the oil light on for those 15-20 seconds at startup?
Old 03-01-2012, 09:55 AM
Gary Haupt's Avatar
Yes, I am very aware of damage due to low oil and no, the low oil light does not come on. Recalling too, that the engine has been checked by the Honda tech and this is his diagnosis, with no mention of wrong oil or otherwise.
Gary Haupt
Old 03-01-2012, 11:23 AM
Something just occurred to me...what engine is in your SF? I remember the 3.3 and 3.8L Lambda motor in the Azera and Sonata (back around 2006 or 2007) had a problem with the timing chain tensioner that would cause a startup noise. I believe there was a recall or TSB on it. Let me see if I can find the info about it.
UPDATE:
https://www.hyundaiforum.com/forum/h...nocking-11223/
https://www.hyundaiforum.com/forum/h...start-up-5570/
https://www.hyundaiforum.com/forum/h...-startup-6621/
https://www.hyundaiforum.com/forum/h...-problem-7868/
Here's the TSB: TSB 06-20-002
It's for before 2010 but it could still be the same problem. Either way, it should be covered under the warranty.
Old 03-02-2012, 10:08 AM
Gary Haupt's Avatar
NovaR...thanks for that and I will find out what engine there is onboard.
Gary Huapt
Old 03-11-2012, 06:02 PM
ernied's Avatar
also if it is the 2.7 or 2.4 it could be the oilfilter.there was a sign at my dealers that stated if it was the filter you would have to pay for a new one plus labor.something about some filters bypass valve was affected by the cold especially the cheap frams and stp filters.
Quick Reply: Deep engine noise in 2010 Sante Fe
