No speed/acceleration
Old Jul 3, 2010 | 06:41 PM
sgreiley's Avatar
Default No speed/acceleration
My 2004 Santa Fe will accelerate up to about 40mph. When you hit press down on the gas petal it revs up but doesn't accelerate, will even downshift but no acceleration.
A friend thought it was the fuel pump and changed it out...ouch. but dealer didn't have the fuel filter.
Any suggestions to this problem?
Old Jul 3, 2010 | 06:49 PM
kerryman71's Avatar
I had the same problem with my wife's 2005. Turned out to be that
squirrels had decided to move into the engine compartment and ate
the wires. Start by taking the plastic engine cover off. You may
find parts of a nest. Also look inside the air filter compartment. I
found about 20 acorns in there as well as other materials. Good luck.
John
Old Jul 4, 2010 | 02:30 AM
sgreiley's Avatar
no squirrels....any body else got a quess?
Old Jul 4, 2010 | 07:32 AM
kerryman71's Avatar
Is the check engine light on by any chance?
John
Old Jul 6, 2010 | 08:00 AM
sgreiley's Avatar
Yes it is. I'd appreciate any help / suggestions...
Friend at garage thought it was fuel pump and changed it out.. only paid his cost for it from dealer.
He said it had a code for the tps and maybe something else.
Stan
Old Jul 16, 2010 | 06:22 AM
beanograig's Avatar
Does the same problem occur when in tiptronic mode. Does the vehicle accelerate when the accel pedal pressed lightly.
MN220_3
Nov 2, 2008 05:18 PM
jpjbarber
Mar 15, 2008 02:35 PM
99_elantra
Oct 18, 2007 08:16 AM
zierk0310
Aug 2, 2007 05:24 PM
skuenkel
Aug 29, 2006 03:04 PM
