Fog lamps on an '08 GLS model
New user/owner here. I would like to install fog lamps in my Santa Fe. Is there a way to install "factory" fog lamps in an '08 GLS model? Is the "main" harness wiring in place and all you have to add is the switch, and connector harness(es), & lamps? I know that some manufacturers are building harness bundles with all wiring included, to save money, which means you just have to find the right cannon plug connector, and connect the plugs.
I also noticed that the front fuse box has a fuse in the "fog lamp" location, even though there are no fog lamps installed.
Any advice would be greatly appreciated!
bicheck
05-26-2015 03:17 PM
mntbiker2008
08-24-2008 11:45 AM
