Roof antenna removal and replacement
Old Aug 28, 2011 | 08:53 AM
Trooper's Avatar
Default Roof antenna removal and replacement
Hey guys,
I have a 2010 Santa Fe and I need to remove the antenna on my roof and replace it with a new one since the other snapped off, but I'm not sure where to start. Any advice would be much appreciated.
Old Aug 29, 2011 | 08:14 AM
Replacement
1. Remove the rear roof trim.
2. Disconnect the antenna connectors (2EA) to the feeder cable connectors.
(A : AM/FM, B : XM)
3. Disconnect the 1P power connector from the roof antenna.
4. Remove the SDARS roof antenna from the roof panel hole after loosening a nut.
5. Installation is the reverse of removal.
Old Jan 31, 2012 | 04:41 PM
dumpsterdan's Avatar
Default Headliner removal??
To replace the roof antenna do I have to completely remove the headliner or can I just remove the rear clips and drop the back of the headliner enough to access the antenna?
Don't want to start the project until I know how deep I have to go.
Thanks
Old Feb 1, 2012 | 06:52 AM
Never tried it so I don't know. My guess you probably could just drop the rear part but you would have to be careful not to damage the headliner.
nhusa
Aug 15, 2014 05:19 PM
zainecurtis
Apr 5, 2013 02:34 AM
Ryan Phillips
Jan 4, 2012 01:12 PM
Rippie
May 1, 2011 12:23 PM
