'06 Sonata ATF change
Old Nov 17, 2010 | 08:42 PM
fritz's Avatar
Default '06 Sonata ATF change
Do I drain and then drop the pan to change the internal filter? Any flushing of the hoses or tubes to be done also?
Old Nov 17, 2010 | 10:26 PM
Take it to the dealer to have it flushed on a machine. There is no servicable filter in teh trans. It's deep inside the trans. Also, Hyundai automatics REQUIRE SP-III fluid. Most non-dealer mechanics don't know that and will used the wrong fluid (which will damage your trans and void your warranty).
2006 Sonata Owners Manual:
Hyundai TSB 10-AT-002:
Cliffs Notes:
- Only use Hyundai Approved transmission fluids
- 2006 Sonata requires SP-III trans fluid
- SP-IV and SP-III are NOT interchangeable
- Non-approved transmission fluids will cause transmission damage
- Damage caused by the use of non-approved transmission fluid is not covered by vehicle warranty
Attached Thumbnails '06 Sonata ATF change-2006-sonata-9-4.jpg   '06 Sonata ATF change-2006-sonata-6-15.jpg   '06 Sonata ATF change-tsb-10-002.jpg
Old Dec 12, 2010 | 04:08 PM
Allan R's Avatar
Up here in Canada, this service runs about $370.00. Is the trans flush recommended or required?
Old Dec 12, 2010 | 06:05 PM
Drain and fill will suffice.. We dont flush at our place
Old Dec 13, 2010 | 08:14 PM
Allan R's Avatar
You work at a service shop? How many quarts do you put back in after the drain? I think I remember seeing in the manual the transaxle takes about 10 quarts or so? I have an 07 Sonata with the 3.3 V6 and shiftronic 5 speed. I noticed that some of the shifts are a little rough at times. The car has now got almost 50,000 miles and I dont know if the PO had the trans service at 25,000 or not. Probably the safest thing to do is assume it was not done.
Smhusker
Feb 2, 2017 04:33 PM
EsteroTennis
Apr 12, 2013 08:53 AM
bobisnext
Nov 1, 2008 08:51 AM
nicokpe
Mar 24, 2008 04:10 AM
fathomx
Mar 28, 2006 09:09 PM
