2003 Hyundai Sonata Fog Light HID Conversion
Old Oct 11, 2010 | 10:19 PM
Eppsilan's Avatar
Default 2003 Hyundai Sonata Fog Light HID Conversion
I recently bought a HID kit for my fogs (9006). But the problem is, as soon as i plugged them in and attempted to turn them on, I blew a fuse. Does anyone have any suggestions on what I could do to get my Fogs working?
I have HIDs in my Lo's and my Hi's and they work just fine. But the Fogs are the problem....
I have a full HID kit from Xentec, (Ballast, Harness, Bulbs, Etc)
Help Anyone?
Old Oct 12, 2010 | 07:14 AM
I'd contact the people at Xentec.
Old Oct 12, 2010 | 12:55 PM
rallyman's Avatar
Re-check all your connections to make sure they are all tight and correct. You must have a short somewhere due to the installation of the kit if the fogs were working properly before. Otherwise, as stated, contact the seller as there may be a defect in the kit components.
Old Oct 13, 2010 | 06:06 AM
Eppsilan's Avatar
I hooked up the fogs to my Lo-Beams, and they work just fine. Im pretty sure that its all hooked up correctly.
Is it possible that its just producing too much power, and the stock harness / other stuff, just cannot handle it?
I will attempt to contact Xentec, but I dont know if they will be able to help
Old Oct 13, 2010 | 10:31 AM
rallyman's Avatar
If you are sure that all connections were made correctly including polarity then I guess you might want to consider getting a relay harness for the HID kit which will power it directly off the battery and use the factory wiring only to turn on and off.
Old Oct 14, 2010 | 04:41 AM
Eppsilan's Avatar
Good idea man, I will grab one of those, and attempt to get it working.
qwerty8904
Jul 1, 2012 04:59 AM
dcullen
Oct 10, 2010 07:34 PM
Vanga
Aug 5, 2010 09:58 AM
Selassie
Feb 25, 2009 07:54 AM
gmgsonata
Feb 20, 2009 08:19 AM
